WSPR
- MiB
- Позывной: R3KEE
WSPR
Сообщение MiB » 03 дек 2021, 19:55
так pytty читает не пакет а по 1му сиволу:
а логгирование там совсем никакое
наверно стоит попробовать SecureCRT но оно только на работе есть.... а дома че-то не ставил и не ломал....
[03/12/2021 19:52:05]
236 IRP_MJ_WRITE - Request transfers data from a client to a COM port (COM10) - 3 bytes of 3
STATUS_SUCCESS
41 32 0a A2.
238 IRP_MJ_WRITE - Request transfers data from a client to a COM port (COM10) - 1 bytes of 1
STATUS_SUCCESS
0d .
239 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
41 A
241 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
32 2
243 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
245 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
247 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
249 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
251 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
253 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
32 2
255 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
257 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
259 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
261 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
263 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
265 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
267 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
0a .
[03/12/2021 19:53:03]
270 IRP_MJ_WRITE - Request transfers data from a client to a COM port (COM10) - 3 bytes of 3
STATUS_SUCCESS
41 33 0a A3.
272 IRP_MJ_WRITE - Request transfers data from a client to a COM port (COM10) - 1 bytes of 1
STATUS_SUCCESS
0d .
273 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
41 A
275 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
33 3
277 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
52 R
279 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
33 3
281 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
4b K
283 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
45 E
285 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
45 E
287 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
20
289 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
4b K
291 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
4f O
293 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
39 9
295 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
31 1
297 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
20
299 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
34 4
301 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
30 0
303 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
30 0
305 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
30 0
307 IRP_MJ_READ - Transfers data from a COM port to a client (COM10) - 1 bytes of 1
STATUS_SUCCESS
0a .
WSPR
Сообщение R9OFG » 03 дек 2021, 23:50
MiB, проверяйте!
Добавлен таймер ожидания подключения к плате.
Добавлена проверка полученных данных из EEPROM МК.
Добавлена поддержка GPS модуля NEO-6M, подключается на плату +>+, ->- и пин TX GPS модуля > пин A0(PC0). Соответственно выбирается источник времени.
- WSPR_Beacon_3_ver_1_05a.zip
- (54.79 КБ) 154 скачивания
- MiB
- Позывной: R3KEE
WSPR
Сообщение MiB » 04 дек 2021, 14:46
ошибка щас не появляется, но и декода нету.
я так понимаю, когда должна выскочить ошибка отправляется повторно команда которая не выполнилась?
но при этом буфер еще не сброшен, и на команду выдается остаток + часть нового ответа:
IMHO, лучше оставить так как было - WRITE работает, а Read мне не нужно в общем то.
для синхронизации времени напишу свою приблуду,
или поставлю GPS модуль - NEO6 у меня нету, но разных китайцев, от авторегистраторов - штук несколько - там-же обработка идет стандартных NMEA строк?
Код: Выделить всё
[04/12/2021 14:32:56] Written data (COM10)
41 33 0a A3.
[04/12/2021 14:32:56] Read data (COM10)
41 33 52 33 4b 45 45 20 4b 4f 39 31 A3R3KEE KO91
41 33 0a A3.
20 34 30 30 30 0a 41 33 52 33 4b 45 45 20 4b 4f 4000.A3R3KEE KO
41 33 0a A3.
39 31 20 34 30 30 30 0a 41 33 91 4000.A3
[04/12/2021 14:32:57] Written data (COM10)
41 33 0a A3.
[04/12/2021 14:32:57] Read data (COM10)
52 33 4b 45 45 20 4b 4f 39 31 20 34 30 30 30 0a R3KEE KO91 4000.
41 33 52 33 4b 45 45 20 4b 4f 39 31 20 A3R3KEE KO91
41 33 0a A3.
34 30 30 30 0a 41 33 52 33 4b 45 45 20 4b 4000.A3R3KEE K
41 33 0a A3.
4f 39 31 20 34 30 30 30 0a 41 33 52 33 4b 45 45 O91 4000.A3R3KEE
20 4b 4f 39 31 20 34 30 30 30 0a KO91 4000.
WSPR
Сообщение R9OFG » 04 дек 2021, 16:36
повторный запрос идет только в том случае если принятая строка меньшей длины чем ожидается, заполнение соответствующих полей происходит только в случае принятия строки ожидаемой длины. На скриншоте видно полученные данные QTH локатора после проверки не соответствуют формату (первый и второй символы только латинские буквы, третий и четвертый символы только цифры от 0 до 9), потому поле и не заполнилось. Естественно и кнопка Write не разблокировалась. Такая ситуация больше склоняет к несоответствию скоростей, кварц каким номиналом тактирует МК?
Пока не догоняю в чем причина, у меня сутки в цикле чтение всех блоков шло, ни одной ошибки.
Ждет только одну строку (пример ниже), с которой берет время, количество видимых спутников и индикатор качества GPS сигнала (если больше 0 тогда уже и координаты берем)
Код: Выделить всё
/*парсинг строки GPS сообщения*/
Пример сообщения: $GPGGA,153145.23,5501.8492,N,08255.0987,E,1,08,2.0, 0150,M , , , , *31
- MiB
- Позывной: R3KEE
WSPR
Сообщение MiB » 04 дек 2021, 17:01
Кварц 16Мгц.
если-бы скорости не совпадали, была-бы белиберда.
а так - в мониоре. все в норме, в путти все в норме, на линухе в миникоме - все в норме
кроме того что данные поступают не одним пакетом.
может кусо кода выложишь в котором чтение идет? я правда вообще не что по C и по .NET но посмотреть никогда не поздно.
декодирование идет после выполнения каждой команды A3 - то одно заполнится, то другое, и это все моргает, становится write/read, кнопка то активна, то не активна.
1) R3KEE KO91
2) R3KEE KO
3) ---
4) R3KEE KO91
5) R3KEE K
ну в общем по логу должно быть понятно.
1) R3KEE KO91
2) R3KEE KO
3) ---
4) R3KEE KO91
5) R3KEE K
