Сообщение RX1900 » 24 апр 2022, 03:03
:DThank you ! Binns,I found the problem. It's all right now. 73
RX1900
Сообщение kvadro23 » 25 апр 2022, 07:40
Уважаемый Binns , не могли бы Вы сказать какой будет экран в прошивке 4.1 Хотелось приобрести заранее .
kvadro23
Сообщение Binns » 25 апр 2022, 20:07
kvadro23, Прошивка как и все предыдущие заточена под экран ILI9341 2.8, прекрасно работает на приемнике ATS25 с экраном 2.4 дюйма. чуть позже будет отдельная прошивка для экрана ILI9488 3.5 и 4 дюйма
kvadro23
Сообщение IU4ALH » 26 апр 2022, 10:21
Thanks Bernard for this very important info ... for safety, in addition to the 2.8 inch display, I also got a nice 4 inch display .. !! Now we are waiting for you !!
a greeting from me IU4ALH Antonino
IU4ALH
Сообщение Popatik » 26 апр 2022, 22:43
Hello Binns.
Thanks for your fantastic work.
I have a question, how can I remove the background of the numbers?
They are not seen correctly, do I have to modify any Firmware parameter?
In v3. 4 didn't have that problem.
Thank you.
Thank you.
Popatik
Сообщение IU4ALH » 27 апр 2022, 14:37
Hi Popatik ... just set the function with this procedure: -
on the display press on NEXT - SETUP - Digit backlight (remove the white square) - EXIT - and SAVE ..
Done ! hi
Done ! hi
IU4ALH
Сообщение IU4ALH » 27 апр 2022, 14:44
Hi Bernard ... I'm sorry if I do this, but I noticed that several users have problems displaying the frequency when the "Digit Backlight" function is activated.
This is definitely due to some brightness factors, but I have noticed that this varies from display to display ... on some it is fine, on others it is more difficult to view ....
Do you think it would be more useful to eliminate this function, leaving black (as the background) the segments of the unused digits?
hello from IU4ALH Antonino.
IU4ALH
Сообщение Popatik » 27 апр 2022, 15:21
Thank you very much Bernard.
In my case it works perfectly by deactivating that function.
I know I repeat myself, but great job with the Firmware.
Popatik
Сообщение Binns » 27 апр 2022, 22:29
IU4ALH, In version 4.1, this backlight is slightly dimmer. And it is also disabled in the settings.
