Сообщение Binns » 29 мар 2022, 23:17
IU4ALH, There is no technical possibility to test the firmware using a 480x320 screen yet. Therefore, the adaptation will be in the next version after 4.1
Сообщение RX1900 » 23 апр 2022, 18:03
hi,Bernard Binns,my touch screen is reversed , what should i do? 73!
RX1900
RX1900
Сообщение Binns » 23 апр 2022, 22:54
RX1900, what do the following lines look like in your sketch?..
#define SCREEN_V 0
#define SCREEN_H 1
uint16_t calDataV[5] = { 258, 3566, 413, 3512, 4 };
uint16_t calDataH[5] = { 387, 3530, 246, 3555, 7 };
#define SCREEN_V 0
#define SCREEN_H 1
Сообщение RX1900 » 24 апр 2022, 01:10
hi, binns ,i didn't make any changes .Up,down,left and right are opposite Horizontal mirror !
RX1900
Сообщение RX1900 » 24 апр 2022, 01:16
RX1900
Сообщение RX1900 » 24 апр 2022, 01:40
I've tried and nothing has changed
RX1900
Сообщение Binns » 24 апр 2022, 02:11
Ok, change in sketch lines:
uint16_t calDataV[5] = { 258, 3566, 413, 3512, 6 };
uint16_t calDataH[5] = { 387, 3530, 246, 3555, 5 };
