Сообщение IU4ALH » 28 мар 2022, 22:56
Hi Bernard Binn ... just now I have received the email to activate my account on this forum.
I have been following your beautiful work for some time in relation to sketch V_4.0 .... I renew my congratulations, which I had already given you on Youtube.
I had already added the complete FM - RDS services (station name - news and info - timetable) to your sketch, as you already know my dear friend Alex YO2LDK reported it to you in a previous post on this discussion, and now I learn that you have inserted it in your new sketch V_4.1, in a much, much more beautiful and functional way ..!
I think we are all looking forward to this new version of yours .... hurry up ..! We are waiting for you !!
Greetings Binn from IU4ALH Antonino
IU4ALH
Сообщение Binns » 29 мар 2022, 00:05
IU4ALH, Hi! Work on the firmware is proceeding as far as possible. I want to add more features, but now in the next version. Otherwise, the release of firmware 4.1 may be delayed. Soon, I will announce the release of the firmware.
- Позывной: 0000
Сообщение yo2ldk » 29 мар 2022, 08:36
Hello, Binns, can I suggest for screen saver, when radio is active, is good to have frequency in use; and when radio is off, it can be added on display an NTP radio clock (UTC maybe, or local time) ?
Код: Выделить всё
//just for example..
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String dayStamp;
String timeStamp;
void setup() {
// Initialize Serial Monitor
Serial.begin(115200);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// Initialize a NTPClient to get time
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(3600);
void loop() {
while(!timeClient.update()) {
timeClient.forceUpdate();
// The formattedDate comes with the following format:
// 2018-05-28T16:00:13Z
// We need to extract date and time
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
Serial.print("DATE: ");
Serial.println(dayStamp);
// Extract time
timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
Serial.print("HOUR: ");
Serial.println(timeStamp);
delay(1000);
yo2ldk
- Позывной: 0000
Сообщение yo2ldk » 29 мар 2022, 14:38
a button / command ON /OFF for the Si473x, then display come into screen saver and show clock
(ESP32 KaRadio internet have that function)
but is not so important..
yo2ldk
- Позывной: UA6158SWL
Сообщение GenaRostov » 29 мар 2022, 15:39
Прошился прошивкой уважаемого Binns.Прошивка замечательная.Есть один вопрос,у меня почему то неправильно отображаются данные батареи(пин установлен правильный,35.В приемнике включил индикацию батареи).Причем заметил что хоть и значения напряжения неправильные,но по мере разряда они уменьшаются.Сделал фото экрана и на всякий случай платы.В чем может быть проблема?
GenaRostov
Сообщение Binns » 29 мар 2022, 20:11
К сожалению не нашел на Ваших платах делителя напряжения. В Вашем случае, придется паять схему дополнительно, что бы отображался заряд батареи
Сообщение GenaRostov » 29 мар 2022, 20:54
Понятно.Жаль.Схема которую вы приводили ранее?К какому пину ее паять,25 или 35?
GenaRostov
Сообщение IU4ALH » 29 мар 2022, 21:07
Ok...Great..!! have you also foreseen the resolution for 4-inch screens? ...
as YO2ldk had previously suggested ....
IU4ALH
