maksland
- Позывной: 0000
Сообщение yo2ldk » 17 ноя 2022, 22:29
more informations will be good;
receiver is home made or ats, case is all from metal; how far is receiver from router.etc. ?
try to solder a capacitor of 47 uF on 3.3v, it helps in many cases..
yo2ldk
Сообщение kvadro23 » 18 ноя 2022, 08:50
Уважаемый господин BINNS ! Подскажите , какой максимальный энкодер можно поставить с каким шагом на 20, 30, 40,60, 100.
kvadro23
- Позывной: UA6158SWL
Сообщение GenaRostov » 18 ноя 2022, 09:05
Hello friend! The receiver was purchased on Aliexpress. The case is completely metal, Wi-Fi worked at first, there was a problem that when it was turned on, the receiver rebooted. Now it does not work at all, the Wi-Fi icon is not active. When you click on it or turn on Wi-Fi through the menu, the receiver restarts, but Wi-Fi does not turn on. Most likely the problem is in ESP 32. Thanks for the advice, I'll try to solder the capacitor.Specify exactly where to install it, on the power supply or on the power supply of the ESP32 itself?
GenaRostov
- Позывной: 0000
Сообщение yo2ldk » 18 ноя 2022, 16:58
on the esp, but if you find the 3.3V, (see pinouts on web for your esp, else for different esp variant)GenaRostov писал(а): ↑18 ноя 2022, 09:05on the power supply or on the power supply of the ESP32 itself?
because is inside of a metal case, RF (even if is not so much power), can interference with esp, like reflected power in antenna
external antenna is better, you can adapt..
yo2ldk
Сообщение kvadro23 » 19 ноя 2022, 11:34
Уважаемый господин BINNS ! В прошивке 4.13 на какой пин ВЫ сделали управление на антенну ?
kvadro23
- Позывной: нет
Сообщение АРМ » 19 ноя 2022, 14:07
Уважаемый Binns.Приобрел ключ, но еще не активировал, не могу залить прошивку
АРМ
