Страница 12 из 143
Добавлено: 24 апр 2022, 03:03
RX1900
:DThank you ! Binns,I found the problem. It's all right now. 73
Добавлено: 25 апр 2022, 07:40
kvadro23
Уважаемый Binns , не могли бы Вы сказать какой будет экран в прошивке 4.1 Хотелось приобрести заранее .
Добавлено: 25 апр 2022, 20:07
kvadro23, Прошивка как и все предыдущие заточена под экран ILI9341 2.8, прекрасно работает на приемнике ATS25 с экраном 2.4 дюйма. чуть позже будет отдельная прошивка для экрана ILI9488 3.5 и 4 дюйма
Добавлено: 25 апр 2022, 21:35
kvadro23
Bernard Binn - БОЛЬШОЕ спасибо !
Добавлено: 26 апр 2022, 10:21
IU4ALH
Binns писал(а): ↑25 апр 2022, 20:07
Thanks Bernard for this very important info ... for safety, in addition to the 2.8 inch display, I also got a nice 4 inch display .. !! Now we are waiting for you !!
a greeting from me IU4ALH Antonino
Добавлено: 26 апр 2022, 22:43
Popatik
Hello Binns.
Thanks for your fantastic work.
I have a question, how can I remove the background of the numbers?
They are not seen correctly, do I have to modify any Firmware parameter?
In v3. 4 didn't have that problem.
Thank you.
Добавлено: 27 апр 2022, 14:37
IU4ALH
Hi Popatik ... just set the function with this procedure: -
on the display press on NEXT - SETUP - Digit backlight (remove the white square) - EXIT - and SAVE ..
Done ! hi
Добавлено: 27 апр 2022, 14:44
IU4ALH
Hi Bernard ... I'm sorry if I do this, but I noticed that several users have problems displaying the frequency when the "Digit Backlight" function is activated.
This is definitely due to some brightness factors, but I have noticed that this varies from display to display ... on some it is fine, on others it is more difficult to view ....
Do you think it would be more useful to eliminate this function, leaving black (as the background) the segments of the unused digits?
hello from IU4ALH Antonino.
Добавлено: 27 апр 2022, 15:21
Popatik
Thank you very much Bernard.
In my case it works perfectly by deactivating that function.
I know I repeat myself, but great job with the Firmware.
Добавлено: 27 апр 2022, 22:29
IU4ALH, In version 4.1, this backlight is slightly dimmer. And it is also disabled in the settings.
