В Украине такого полно. http://www.kosmodrom.com.ua/ или здесь https://evocom.ua/
Mari-l
Сообщение Radetskey » 12 янв 2021, 09:30
Спасибо за подсказку.
Не в тему но корона задрала. один магаз не работает второй инвентаризация на лакдаун..... нет слов....одно пииииииииии.
Radetskey
magnym
Andy-H
Сообщение I2KBD » 14 янв 2021, 17:51
Good morning from Italy!
I have an original Malahit and all is working fine...
My question is about the sofware. Why we don't have a CW mode? I know there is a CW decoder but the mode selected is still USB or LSB.
Best regards
Alberto I2KBD
Best regards
Alberto I2KBD
I2KBD
Mari-l
- Позывной: UA3WHK
Сообщение Sanek » 15 янв 2021, 01:38
I2KBD, Yes, this is how you can receive and decode the CW signal in any of the modes, either USB or LSB. You can narrow the bandwidth if you need. On my Chinese clone, I checked everything works fine. Good luck.
Sanek
Сообщение I2KBD » 15 янв 2021, 19:11
Hi Mari and Sanek,
yes I know I can receive CW using SSB and reducing the filter width. But every radio has a CW mode that normally select narrow filter and adjust the display frequency based on the note pitch...
Regards
Alberto I2KBD
Regards
Alberto I2KBD
I2KBD
Сообщение R3MW » 21 янв 2021, 16:23
HI Alberto. The fact is that CW differs little from USB and LSB, only in bandwidth and AGC delay time, unlike AM or FM. This is probably why it was not necessary to introduce CW fashion.
73 de R3MW Serge.
73 de R3MW Serge.
R3MW
Сообщение I2KBD » 23 янв 2021, 19:37
Hi Serge,
yes CW can be received in SSB, but switching from SSB and adjusting bandwidth and AGC setting is not very fast and easy. Every amateur radio has both SSB and CW mode. I have shown my Malahit to many OM friends who mostly use CW and many commented: I will never use a radio that doesn't have CW mode!
73s de Alberto I2KBD
I2KBD
